[x] Add retrieval of lyrics from radio stream metadata to WebLyrics?
Topic: [x] Add retrieval of lyrics from radio stream metadata to WebLyrics? (Read 12298 times)
June 29, 2018, 07:10:51 »
sveakul
Карма: +81/-1
Would it be possible to add the ability to retrieve and display lyrics from playing radio stream tracks to the WebLyrics plugin, using the same metadata (if it is present in the stream header of course) as it does for audio files? Then, allow the lyrics to be copy/pasted to a text file if desired while the display is "active." Thanks for your consideration; wasn't sure if this should be in "Suggestions" or here.
Last Edit: July 03, 2018, 20:31:01 by Artem
Re: Add retrieval of lyrics from radio stream metadata to WebLyrics?
June 30, 2018, 14:01:57 »
Карма: +3206/-77
It should work now, if radio stream has correct artist and title fields
June 30, 2018, 20:22:16 »
sveakul
Карма: +81/-1
Thanks for the reply! What I am seeing is that when doing a File Info on a playing song, the Lyrics tab never appears in order to actually try a "download from Internet". It appears for audio files with no lyrics (blank of course), but never for a stream title, only the Basic/Information/Log columns. Here is an example of what is shown for a song containing artist and title metadata in the stream:
The song DOES have lyrics on LyricWiki (
http://lyrics.wikia.com/wiki/Rush:Rivendell
The plugin is loaded and "Find on Internet" option checked in Player/Additional Information/Lyrics. Not sure why no retrieval is then possible.
July 03, 2018, 20:30:56 »
Карма: +3206/-77
Looks like a bug in player. I will fix it soon
Re: [x] Add retrieval of lyrics from radio stream metadata to WebLyrics?
July 04, 2018, 05:01:39 »
sveakul
Карма: +81/-1
Thanks Artem, much appreciated!
