Skin Editor, Skin Engine
Pause Button colored when track is paused - How can i do this?
Topic: Pause Button colored when track is paused - How can i do this? (Read 8540 times)
August 14, 2017, 20:47:49 »
Antonym
Hello, i couldn't find a solution in the help file and i have no coding experience, so forgive me if i ask a stupid question.
I'd like to see when the track is actually paused - for example the "pause" button shows up like it is pushed. (or flashing, that good too)
My first idea was that it should work like the "Mute" button (i'm modifying the Bliss skin)
but when i just replace "acPlayerVolumeMute" with "acPlayerPause" the button icon doesn't work in the same way as it did for the mute function. The texture for the button doesn't use the 6 frames like it did with the "acPlayerVolumeMute"
What is going wrong there, how can this be done?
(i've seen a skins with this function, but i don't have a clue how it works : Bliss compact Dark v1.3 by Vincent Koelo for example)
Re: Pause Button colored when track is paused - How can i do this?
August 14, 2017, 21:07:33 »
Aleksandr009
Карма: +322/-12
Help > Skin structure > Controls > Digital display (TASEDigitsDisplay, TASETimeDisplay) > Exemple: Playback status
August 14, 2017, 23:25:38 »
Antonym
Thank you very much ! - i figured out how it works : now i got the skin how i like it.
