Provide a .TLB file (COM Type Library)
Topic: Provide a .TLB file (COM Type Library) (Read 14919 times)
July 18, 2020, 01:39:00 »
cubis123
Карма: +40/-0
How are the plugin SDK COM interfaces done? What is AIMP written in anyway, I'm assuming Delphi based on the provided headers?
Would it be possible to export a .TLB file describing those COM interfaces?
http://docwiki.embarcadero.com/RADStudio/Rio/en/Working_with_Type_Libraries_Index
http://docwiki.embarcadero.com/RADStudio/Rio/en/GenTLB.exe
Right now to write plugins in C# you can either use a C++/CLI wrapper like aimp_dotnet does or directly use the COM interfaces.
The problem with using the COM interfaces is that you have to write all the binding manually, which is significant amount of work.
Visual Studio comes with a tool that can generate those bindings automatically based on a .TLB file though, so if one could be provided as a part of the SDK it would make a C#/.NET integration much easier and less error-prone.
Re: Provide a .TLB file (COM Type Library)
July 19, 2020, 09:06:31 »
Карма: +3223/-78
Thank you.I will check it
