Skins in the development stage
Kr1eger
[GW+PL+EQ+TC] Silver 2011
Topic: [GW+PL+EQ+TC] Silver 2011 (Read 13590 times)
January 20, 2011, 23:26:10 »
4sk
Карма: +7/-1
Silver 2011 Full Aimp2
Skin editor 2 Create Aimp2
editor3 And aimp 3 Coming Soon
Last Edit: February 19, 2015, 13:57:53 by Soolo
Re: Silver 2011 Full
January 20, 2011, 23:30:18 »
alexxei_ill
Завсегдатай
Карма: +24/-0
надо доработать Плейлист и QFI
Горизонталь не верно растягивается!
а File Info просто не подходит! =)
+1 а так шикарный скин!
January 20, 2011, 23:38:43 »
4sk
Карма: +7/-1
Thank you
will try to resolve the errors here, if given
January 21, 2011, 01:26:43 »
sviperz
Супер Модератор
Карма: +105/-8
Here'n'Now!!
Похоже, постить ошибки придется на "инглише"
Re: [GW+PL+EQ+TC] Silver 2011
January 21, 2011, 08:43:57 »
Модератор
Карма: +427/-7
Скрытая угроза
I use AIMP3, therefore will test this skin in this version...
1. QFI to be change;
2. Menu to be change;
3. In TC (Tray Control) need to remove "Repeat" button (TC.png);
4. May you make animation of buttons on main window more beautiful (GW.png).
January 21, 2011, 11:13:19 »
4sk
Карма: +7/-1
repeat button is removed from the system tray
I can not say anything but tried to make animated buttons now try to
January 21, 2011, 22:06:27 »
D!M!K
Завсегдатай
Карма: +1/-0
BWAAAH
awesome
January 23, 2011, 16:49:30 »
Андрей Бубнов
Карма: +25/-0
What about EQ Window like this? Screenshot 1
Bug with stretching playlist. Screenshot 2
For remove bug look to the scrennshot 3
Please add Playlist Tabs.
Reply #8 on:
January 23, 2011, 18:01:19 »
4sk
Карма: +7/-1
Thank you for mistakes you specify
They'll try to do
Added new version
Reply #9 on:
January 24, 2011, 11:03:45 »
LS
Карма: +31/-21
Проблема с отсоединеним плейлиста
google translator:
The problem with disconnecting Playlists
Видео (Video):
http://depositfiles.com/files/4bk3pu7ml
(8.47 MB)
Reply #10 on:
February 25, 2011, 09:11:16 »
dark santa
Карма: +1/-0
классный скин, выглядит отлично, +1 однозначно. Довести до полной готовности будет супер
Kr1eger
