Playback filter addon ?
Topic: Playback filter addon ? (Read 95 times)
August 26, 2026, 10:16:50 »
ultraboom
Hello,
I have rips of CDs (flac, cue) with track names containing some keywords.
While playing, I would like to skip the tracks containing a keyword.
Use case: skip all recitativo of an opera recording
I would like to avoid any playlist preprocessing, and rather filter on the fly.
Is there an addon that allows to do that ?
Or else, can the SDK support that ? (enable/disable a track, callback before playing a track...)
Thanks
Last Edit: August 26, 2026, 20:55:30 by Soolo
Re: Playback filter addon ?
August 26, 2026, 10:34:09 »
Карма: +3219/-78
You can use smart-playlist that will filter the tracks that contains a specified keyword. So, your playing playlist will not contains the tracks that you don't to listen
August 26, 2026, 12:31:46 »
ultraboom
Excellent
