Find New Files
I've noticed that new files are simply appended to the bottom, even though I have "new files at the top" enabled.
Can I exclude specific subfolders from a monitored folder in the preimage? I know file extensions can be excluded, but what about folders?
Send to other playlist?
It legacy solution, don't use it if you using the smart-playlists
Yes, sorting template are applied to content after synchronization. What sorting template you have specified for the playlist?
Yes, sure. Go to folders tab, click add and select folders that you want to scan (uncheck folders that you want to exclude)
No, because the command requires to select target playlist
Just stick to reload pre-Image option?
Ive set up %!%Year - %!%FileCreatedDate - %FileDir - %TrackNumber so what I do, I just copy new folders/albums in the folder and I hit R-reload preimage...
This would be great but not possible, If you setup only one parent folder to be monitored you cant open it and select/deselect specific folders...
yes, just setting up what specific key or number do ... just linkin number and list would be cool
Excluding Subfolders:Regarding the suggested workaround of dragging and dropping folders into the list-I understand how that works. However, what if your Music folder contains over 1 000 album folders that you're constantly updating, and you only want to exclude a single folder? Wouldn't that mean you'd have to manually add every new album to the list each time?
How often do you add an album to your music folder but don't want it to be indexed?
Personally, I put temporary songs in a temporary folder and only keep the ones I like in Music.
