DennoN
[?] [2716] Windows 11 Home RPC Error
Topic: [?] [2716] Windows 11 Home RPC Error (Read 1561 times)
May 18, 2026, 00:41:32 »
Gummo
I get this error if I shut AIMP down and immediately double-click an MP3. I then wait a few seconds before successfully repeating. It seems to be that when I close AIMP, it's taking some time to competely close.
I've tested with VLC player which doesn' t have the issue.
Last Edit: May 20, 2026, 00:04:28 by Artem
Re: Windows 11 Home RPC Error
May 18, 2026, 08:15:56 »
Карма: +3215/-78
Please try to do following steps:
1) Uncheck all options in the "Options \ System \ Integration" page
2) Apply changes and close the application
3) Restart the computer
4) Remove the AIMP-ContextMenu.ini from С:\Users\<UserName>\AppData\Roaming\AIMP\ folder
5) Restore options state in the "Options \ System \ Integration" page
6) Apply changes
May 18, 2026, 13:41:19 »
Gummo
I tried that to the letter, Artem - no happy result. I then installed AIMP on my old W10 laptop - issue occurs there too.
May 18, 2026, 13:48:15 »
Карма: +3215/-78
What app version you've installed?
May 18, 2026, 14:23:54 »
Gummo
v5.40.2716
May 19, 2026, 13:42:28 »
Карма: +3215/-78
Please, try the following steps:
1) Go to the "file associations" settings section
2) Uncheck the "add to default programs" box
3) Apply the changes and close the program.
4) Check the "add to default programs" box
5) Apply the changes
6) Click on the "file types" button and select all the desired types in the window that opens.
May 19, 2026, 15:25:46 »
Gummo
Sadly, it didn't work, Artem.
Re: [?] [2716] Windows 11 Home RPC Error
May 20, 2026, 00:05:24 »
Карма: +3215/-78
Unfortunately, I've no idea what also we can to try...
Reply #8 on:
May 21, 2026, 16:16:15 »
Gummo
Thanks very much for your kind attention anyway - maybe a Windows 11 issue at the end of the day.
DennoN
