FDK AAC Encoder [aimp5.40]
Topic: FDK AAC Encoder [aimp5.40] (Read 8759 times)
March 13, 2025, 09:26:56 »
Карма: +1408/-191
AAC/M4A Encoder (FDK) v1.0.9
| 2026-10-05 | 809 KB |
App Version
: v5.40 or newer
Type
: Encoders
Target
: Windows 32-bit, Windows 64-bit
Based on
fdkaac by nu774
using the Fraunhofer FDK.
.M4A
Last Edit: March 13, 2025, 13:47:53 by Soolo
Re: FDK AAC Encoder [aimp5.40]
October 22, 2025, 20:12:42 »
Armacadia
Unless I'm misunderstanding something, this seems to produce much worse quality result than the old standalone FDK encoder at similar settings, link to which was provided on this forum while 5.30 was still the actual version.
I have tried coverting a FLAC file to 320kbps CBR; the first screenshot shows the spectral range of the original FLAC file, screenshots 2-3 show the old encoder at CBR 320 (no format conversion, channel mixing + dithering + anticlipping on in the converter settings), 4-5 show this encoder at CBR 320 MPEG-4 AAC LC (still no conversion, mixing, dithering and anticlipping on). Output file size happens to be about the same in both cases.
Could be not the encoder itself to blame but its xml manifest, I dunno?
