Directory tree appearance
Topic: Directory tree appearance (Read 2179 times)
September 08, 2025, 00:45:00 »
bluedraft
Карма: +1/-0
Hello,
I just realized that when you select “no grouping” in the library, folders that only have one subfolder don't show the expand/collapse arrow. Instead, the single folder is displayed right next to the main folder, and honestly, it looks ugly. , see
Is this normal or it's a bug?
Re: Directory tree appearance
September 08, 2025, 08:13:55 »
Карма: +3196/-77
Quote from: bluedraft on September 08, 2025, 00:45:00
it looks ugly
No, it does not.
Anyway, you can disable the "combine empty grouping levels when possible" option in app settings \ player \ music library
September 08, 2025, 18:55:28 »
bluedraft
Карма: +1/-0
Wonderful, thanks a lot
