Bliss 4K version 2.43
Actually I see you can make one with the controls on the bottom from the latest Skin Editor, by loading the built-in Bliss 4k project and in the AIMPMainForm section only selecting the "mwCaptionLayoutClassic" instead of "mwCaptionLayoutModern." Then if you just build the skin as-is you get one minus the extras I had added, plus you'd have a project file to make any edits you wanted later.
