Reproduction starts random and not sorted by track
Topic: Reproduction starts random and not sorted by track (Read 2362 times)
April 01, 2023, 10:46:15 »
StVarg
Hi everybody!
Since the latest update, my playlist do not start as they used to.
I want songs to be played sorted by track number. ALWAYS! It always worked that way.
Once, I would simply select the files in the folder on my PC and then select play with AIMP and the reproduction would start from song numer 1 to the last one.
Now it authomatically sorts song either in alphabetic order or it starts the reproduction randomly.
I check all the settings and they seems fine.
Can someone help me please?
Thank tou
Re: Reproduction starts random and not sorted by track
April 01, 2023, 12:10:32 »
Карма: +3209/-78
Hello,
Quote from: StVarg on April 01, 2023, 10:46:15
What settings are fine? By default, AIMP sorts the files that imported from external apps by it filenames
