Delete Duplicates from a playlist?
Topic: Delete Duplicates from a playlist? (Read 5035 times)
November 05, 2021, 05:19:22 »
DXPOHIHIHI
So I have these duplicate songs from a playlist, I downloaded from a spotify playlist using spotiflyer. I have two playlists which contain the same song. I tried the (-) and remove duplicates but they still have duplicates on the two playlists I have. Any tutorial on how to delete one duplicate on a playlist so I only have one song per playlist?
Re: Delete Duplicates from a playlist?
November 05, 2021, 05:32:09 »
sveakul
Карма: +81/-1
Are you saying that if you right-click an item on a playlist, and choose "Remove selected files", that file is NOT removed from that playlist? Certainly works fine here, version 5.0 build 2335.
November 05, 2021, 14:08:13 »
DXPOHIHIHI
Yes that works but I can't find all the duplicates manually, I want it to delete the duplicate without me searching for it.
January 21, 2022, 00:24:20 »
gwbret
This seems like such a basic player function. I wonder why it is so hard to find a way to do this.
