vst plugin Installation
Topic: vst plugin Installation (Read 21112 times)
February 16, 2021, 19:24:37 »
musik
Hello Aimp Enthusiasts,
i have a problem to install an vst-plugin.
The plugin is called Aroma from ploytec. I have downloaded the *.zip and unpacked the folder. In the directory aimp/plugins i have generated a folder named aroma. Then i copied aroma.dll into the folder aimp/plugins/aroma.
Aimp and PC are restarted, but in the extensions there is no aroma entry.
What do i wrong?
Operating System: WIN10 Pro; Vers.1909
Aimp Version: v4.70, build2236
Re: vst plugin Installation
February 16, 2021, 20:20:21 »
sveakul
Карма: +81/-1
AIMP cannot load VST plugins directly as it has no built-in VST host. You can however add a separate plugin host, and then add your Aroma VST to that. See the link here for some more info:
https://www.aimp.ru/forum/index.php?topic=58732.15
