Skin Editor, Skin Engine
Change TextTestDisplayEX Template With Custom Provider
Topic: Change TextTestDisplayEX Template With Custom Provider (Read 6100 times)
July 14, 2019, 03:04:50 »
Gilang4321
Hello Everyone,
How can i change TextTestDisplayEX template with custom provider.
Example
- if i press button 1 then TextTestDisplayEX Template will be "HELLO"
- if i press button 2 then TextTestDisplayEX template will be "OKAY"
- if i press button 3 then TextTestDisplayEX template will be "alright"
Re: Change TextTestDisplayEX Template With Custom Provider
July 14, 2019, 15:07:36 »
Black_AVP_Bim
Тестер-Ветеран
Карма: +2094/-84
The example in the attachment.
July 14, 2019, 19:38:59 »
Gilang4321
Thanks for the help!!!!
July 14, 2019, 20:19:23 »
Gilang4321
sorry to ask again, is there anyway to make the text to become vertical ?
Example:
Original "Lorep ipsum"
Vertical "Lorep"
"Ipsum"
July 14, 2019, 21:13:24 »
Black_AVP_Bim
Тестер-Ветеран
Карма: +2094/-84
Многострочный текст поддерживается только в TASETextDisplayEx.
Если это статический текст, то можно ввести его в поле Template с помощью редактора.
Google translator:
Multi-line text is supported only in TASETextDisplayEx.
If this is a static text, you can enter it in the Template field using the editor.
