Tag Editor - save on return key
Topic: Tag Editor - save on return key (Read 4047 times)
July 14, 2018, 15:27:26 »
olorinh
Hey,
Is it possible to change (or request) the Tag Editor's default action to save on return key?
For example, in the ID3v2 tab, all fields have no action on return key, except Comment. Therefore is it possible to map the return key for all fields except comment, so that the tag edits can be quickly saved?
Currently it takes a long time to 'tab' to the Save button, or move the cursor to Save, when doing multiple edits.
Thanks in advance.
Re: Tag Editor - save on return key
July 14, 2018, 16:20:52 »
gr-e
Карма: +170/-3
Ctrl+S?
July 15, 2018, 18:46:28 »
olorinh
I tried CTRL + S just now. That neither saves the tag edits nor closes the window
