context menu
Topic: context menu (Read 5671 times)
context menu
October 07, 2020, 16:13:34 »
wynford
Карма: +2/-1
All of a sudden, with AIMP v4.70, build 2231, the context menu in windows 10 explorer for AIMP has disappeared.
How can I get it back?
Re: context menu
October 07, 2020, 16:38:33 »
𝗞𝗡𝗧𝗥𝗢
Карма: +76/-1
Hi! You can email me or contact me via Telegram.
Hello,
Have you checked
MENU
Options
System
Integration
Add to Explorer context menu
Re: context menu
October 07, 2020, 16:45:17 »
wynford
Карма: +2/-1
I have it fixed... the solution was in the help file... except it said to delete AIMP-Menu.ini, but there was no such file... I deleted the AIMP-ContextMenu.ini and that worked.
context menu
