Skin Editor, Skin Engine
Transparency on AIMP4 default Bliss Skin
Topic: Transparency on AIMP4 default Bliss Skin (Read 7796 times)
April 19, 2016, 20:19:31 »
Raven
Hi,
i try do edit the Bliss skin to feet my Rainmeter theme with transparency but can't get it to work on the "SplitView" panels.
In the editor the transparency seems to work but not after creation.
I you look at the LibraryPane/MLGroupingTree in the attached pictures, in the skin editor i can see the background (i set it to green) but the result it's black with no transparency.
In the skin editor :
Result :
Thanks for your help.
Last Edit: April 19, 2016, 20:29:43 by Raven
Re: Transparency on AIMP4 default Bliss Skin
April 19, 2016, 21:08:19 »
Карма: +476/-74
Transparency does not support all elements
April 19, 2016, 21:31:28 »
Raven
Hi,
thanks for your quick answer.
