| AIMP for PC > Ошибки и замечания / Bugs |
| [x] [3060] AIMP on ARM. Hangs when I open a file in it |
| (1/2) > >> |
| ohm-ish:
Testing AIMP on laptop with windows ARM When I doubleclick an mp3 file it opens AIMP but there's a blue circle. Nothing happens, it hangs and is totally unresponsive, can't even close it, have to ctrl-alt-del and quit it But if I drag the file to AIMP instead it can play fine. But doubleclicking it goes wrong But doubleclicking to open is needed ;) |
| Artem:
Does it opens correctly via context menu command? |
| ohm-ish:
Hi No, it's the same And the player hangs (with the blue spinning circle icon) and I cannot quit it or do anything |
| ohm-ish:
But.. if the player is already open, and I doubleclick on the mp3 in my folder, then it opens and plays fine in it |
| Artem:
I think the issue was related to this bug report: https://aimp.ru/forum/index.php?topic=77697.0 Please, wait for an update. |
| Navigation |
| Message Index |
| Next page |
