The sorting issue for Chinese filenames still exists in the nightly build
Default sorting by file name
I sorted the files by name in the "My Music/Folders" section.
Here is nightly build:https://disk.yandex.ru/d/PlqxQzwGyKa-rANew string comparing algorithm is used inside playlist (music library is not yet updated to use it).Waiting for your feedback.
Please, try this build:https://disk.yandex.ru/d/jWWx_6E5r0mGIQ
Webpage prompt: Не удалось скачать файл. Попробуйте позже.Are there any other file sharing methods? Can you send it via Telegram, VK, or email?
In the playlist, sorting Chinese songs by filename is still not sorted by Pinyin
Playlist is ok. Will the music library use it in v4.40?
